2019-03-31
05:31 PM
- last edited on
2023-05-24
08:13 AM
by
Rubia Torres
Solved! Go to Solution.
2019-04-01 05:25 PM
Barry wrote:Thanks for adding that, Barry. And, Michael, you would use Partial Structure Display options to entirely turn the baseboard on or off for views thet need or don't need it (e.g., don't want the extra lifework on a floor plan).
Michael wrote:If you can upgrade to version 22, then you can use 'Modifiers' in your complex profiles.
Thanks, but if it’s part of the complex profile I won’t have control over where it appears and where I’d like a certain part of a wall not to have baseboard.
So you can have your baseboard (skirting) that is stretchable in size.
To hide it simply stretch the height or width to zero.
2019-04-02 02:56 AM
Michael wrote:Your image is too wide.
"The image must be at least 0 pixels wide, 0 pixels high and at most 1920 pixels wide and 1200 pixels high. The submitted image is 1976 pixels wide and 1080 pixels high."
2019-04-08 11:40 PM
Michael wrote:I like to use object/library parts that you can adjust for length and miter for base and crown. But if you do like to use the Wall Accessory Tool you can play some trick with the zone boundaries around the doors and then you can delete the generated accessory you don't want.
Hi, I’ve tried using the beam tool and magic wand some baseboards into a room and although it works well the baseboard runs across door openings.
Without having to go in and cut out the door spans and drag and mess around is there an automated way to do this?
I haven’t tried the baseboards in goodies only because I have yet to see a video of this going well also.
I really would like to stay within the program to accomplish the task of baseboards. In Revit you can add baseboards as “sweeps” to a wall profile.
I’m hoping there is some kind of secret Archicad option buried somewhere in the program.
2019-04-08 11:54 PM
2019-04-13 07:04 PM
2019-04-13 09:56 PM
2019-04-14 01:00 AM
Michael wrote:Many of us will disagree with the above quote, unless you replace the words "real architect" with "old school architect". Of course you wouldn't show trim in any view other than sections and 3D ... but why would you NOT show it in those views? If you provide a client with a virtual model for the free BIMx viewer ... wouldn't they want to see things trimmed out (at a certain point in design development)? A benefit of virtual building in 3D is that you can cut a section anywhere and see the right thing without having to detail the section manually, at a risk of future errors/omissions.
He said, “a real Architect will show the baseboards and millwork in a cross section detail with model number and dimensions etc. We’re not trying to build a virtual Barbie house. Millwork in any floor plan will only add to the confusion of the important elements in a drawing which are the walls and structure.” Or something to that effect.
2019-04-14 04:48 AM
2019-04-15 02:15 PM
2019-04-16 06:58 AM
Michael wrote:It would only take a few seconds to cut the beam at doors, I don’t see what the issue is with using beams I have done this to model coved vinyl skirtings across a whole hospital redevelopment and took no longer to model correctly than drawing 2d overlay in sections / int elevations
I wish the beam tool simply had a button to select, “hide across door or wall openings”.
This would truly be a millwork tool without compromise.
