2023-08-24 05:40 PM - edited 2023-08-24 05:41 PM
Beam connection Why is this?
It's normal in 2D, but different in 3D.
What should I do in this case?
It's not like I have to use SOE, right?
Solved! Go to Solution.
2023-08-25 04:46 AM - edited 2023-08-25 04:46 AM
I am not sure why the 2D & 3D don't match.
Nothing to do with building material strength and beams don't have junction order like walls do.
Only solution I can see it to reduce the length of the angled beam's reference line, so it does not touch the other reference line.
2023-08-25 09:35 AM
I guess you could put it on a layer that has a different number assignet to it; usually a layer has 1 next to it, if you create a layer that has the number 2 next to it, and put one beam on that layer, they will not interact.
.Kamelite
2023-08-25 09:57 AM
You can also offset one of the refenceaxis.
2023-08-25 10:26 AM
But not if you need the axis in the centre on plan.
