Board and Batten "fill pattern" - best way?
rob2218
if anybody has created this fill type already, surely would like some guidance on how they did it.
We have a "board and batten" type fill which needs to be represented in elevation.
see attached image.
was thinking something simple, perhaps one or two lines to designate the boards, with stipple type graphics to designate concrete.
How best to achieve this fill creation?
i>u
Edgewater, FL!
SOFTWARE VERSION:
Archicad 22, Archicad 23
Windows7 -OS, MAC Maverick OS
7 REPLIES 7
rob2218
nuttin' huh?
i>u
Edgewater, FL!
SOFTWARE VERSION:
Can't really tell what you want, Rob. Board & Batten is typically a vertical installation... horizontal would require top z-flashing for every batten...?
rob2218
ok.....here's the tutorial for anyone who wants to create their own custom fill patterns.
pretty simple.
Just make sure you toggle the appropriate buttons.
http://helpcenter.graphisoft.com/guides/archicad-18-int-reference-guide/documentation/fills/create-o...
i>u
Edgewater, FL!
SOFTWARE VERSION:
rob2218
Sorry...perhaps I misnamed the pattern I was looking for. "Batten"? perhaps is what I was looking for?
it's the surface texture which has horizontal lines and parts of the concrete seep thru the horizontal boards. Gives the rough concrete surface an interesting look where the wood grain sometimes is seen "IN" the poured concrete surface itself.
i>u
Edgewater, FL!
SOFTWARE VERSION:
Stress Co_
I'd call that "Board Formed Concrete"
Marc Corney, Architect
Red Canoe Architecture, P. A.
rob2218
That's it...."Board Formed Concrete"....sorry my bad.
Thanks sir.
i>u
Edgewater, FL!
SOFTWARE VERSION:
Steve Jepson
Bump in rendering is how to do that.
