Can I change the lenght of dashed lines?
Paopao
Hi guys,
is there a way to change the length of the dashed lines? They are way too long for a draing I am doing.
Any help is as usual appreciated. Thanks
PP
AC26 EDU • WIN 10 • Intel Core i7 2.8 GHz• 32G RAM• NVidia GForce GTX 1080
James B
Options > Element Attributes > Line Types
Find your dashed line, and then move the flags in the preview to widen or reduce the gap (or enter new values).
Also note the scale you are using as this will affect the appearance of your dashes.
James Badcock
Eduardo Rolon
Though I would make a Duplicate of the Line before editing it.
Eduardo Rolón AIA NCARB
AC29 US/INT -> AC08
another Moderator
David Maudlin
Paopao:
The Dash and Gap of lines can be edited by going to Line Types... dialog box, selecting the line type, and changing these values. You may want to create a new line type (select one of the existing line types and click the "New..." button) so that your existing line types stay as they are. Also, note whether the line type you are editing is Scale with Plan or Scale Independent so you can control the result depending on the scale of the drawing.
David
David Maudlin / Architect
www.davidmaudlin.com
Digital Architecture
