2011-09-30
08:02 PM
2023-05-24
07:58 PM
Rubia Torres
2011-10-03 07:20 PM
2011-10-03 08:06 PM
2011-10-04 11:19 PM
2011-10-05 10:31 AM
2011-10-05 10:44 AM
rocorona wrote:And as Duane suggested this could be controlled through the MVO settings for objects.
Save the Slab as an Object and use it as the SEO Operator.
Edit the Object adding a boolean parameter, call it "hidden".
Then add this, as the first row in the 3D Script:
IF hidden THEN END
This way you can switch the operation on and off.
