Can't see separator lines of composite walls in section.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
‎2011-12-30
10:52 PM
‎2023-05-24
01:00 PM
Rubia Torres
When I select the wall in section I can see where the lines should be.
Why don't all the separator lines show up?
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2012-01-02 02:43 PM
www.davidmaudlin.com
Digital Architecture
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2012-01-02 06:50 PM
Til wrote:I bet that's it! I will give it a try. Thanks!
Steve,
as you are using the same fill for different skins, in section the rule is : same fill=merge.
If you want to separate them in section just duplicate the original fill and use alternatively for example empty_fill/empty_fill1/empty_fill/empty_fill1 etc
In plan view the rule is not the same all skins show and never merge except if you set them accordingly.
Some like this subtle difference, some don't
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2012-01-02 07:00 PM
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2013-04-21 08:21 PM
i tought i was having the same problem as Steve but my problem is a bit diferent.
i noticed that in sections i can´t change the separator line color. i wanted all black fills with white lines separating them and i can't do it.
i tried red lines, blue etc, it only changes in plans. even if you try the normal fills with red separation lines it won´t change in sections. it always apears a black sparator line.
can someone help me?
thank you
(P.S) - i got it!!! thank you
- « Previous
- 1
- 2
- Next »
- « Previous
- 1
- 2
- Next »
