Can't see separator lines of composite walls in section.
I see the separator lines in plan view but not in section.
When I select the wall in section I can see where the lines should be.
Why don't all the separator lines show up?
13 REPLIES 13
David Maudlin
I think Til has the solution.
David Maudlin / Architect
www.davidmaudlin.com
Digital Architecture
Til wrote:
Steve,
as you are using the same fill for different skins, in section the rule is : same fill=merge.
If you want to separate them in section just duplicate the original fill and use alternatively for example empty_fill/empty_fill1/empty_fill/empty_fill1 etc
In plan view the rule is not the same all skins show and never merge except if you set them accordingly.
Some like this subtle difference, some don't
I bet that's it! I will give it a try. Thanks!
Yes. That was it.
hello everyone i´m new here and bit new to archicad also.
i tought i was having the same problem as Steve but my problem is a bit diferent.
i noticed that in sections i can´t change the separator line color. i wanted all black fills with white lines separating them and i can't do it.
i tried red lines, blue etc, it only changes in plans. even if you try the normal fills with red separation lines it won´t change in sections. it always apears a black sparator line.
can someone help me?
thank you
(P.S) - i got it!!! thank you
