adrianasofiasm_
Cant create morph in 3D in higher stories
Hi!
I've been using the morph tool to create a rectangular slab (as pictured), and I've been doing it on the elevation tab since it's easier to get the shape right. I did it plenty of times, but literally all of a sudden, without me having touched any setting or key, I suddenly can't draw a morph on the elevation tab. I then tried to do it on the 3D (as I have done multiple times in the same file), but then, I can't bring it down or up de z axis, because the grid moves up to the starting point of my morph (Notice the grid is at ground level in the first image, when I have not yet began to draw the morph). THEN, I gave up and tried drawing it on the floor plan in the story in which it is supposed to go, but when I go to 3D to see how it looks/manipulate it, I couldn't even find the morph. Turns out, It was below the ground 0 level, under the "terrain" slab. I tried quitting archicad and restarting it, but the problem persists.
 Thanks!!
AC28 USA - MacBook Pro 14" - Apple M1 Pro - 16 GB
1 Reply 1
cuba
I don't know why you can't draw morphs but for rectangular shapes it might be better to use the slab tool or wall tool. I never draw morphs; I only use morphs when I want to modify a library element....
Apple M1 Max 32 GB
Latest AC
