Composite Intersections
Can anyone confirm wether one can have more than one/two skin(s) cleanly intersecting at a T-junction. The problem occurs where a seperating wall (two similar plaster skins, a core comprising two identical block skins with an airspace cavity) meets an external cavity wall (with a plastered inner leaf of the same blockwork and the same airspace cavity).
The result is one block leaf of the seperating wall and its plaster finish cleans to the inner leaf of the cavity wall. The rest looks a mess!
4 REPLIES 4
Djordje
Screenshot please!
Djordje
ArchiCAD since 4.55 ... 1995
HP Omen
Screenshot please!
It would indeed help us to help you 😉
Took me a while to work out how to do a screenshot!
Here goes:
( I dont know if that has worked - If it has there should be a jpeg attachment but I cant see it in this window)
Wavydavy - CSP Architects
Petros Ioannou
There is a similar topic at
http://archicad-talk.graphisoft.com/viewtopic.php?t=832
HTH
Petros
ArchiCAD 22 4023 UKI FULL,
Archicad 21 6013 UKI FULL, ArchiCAD 20 8005 UKI FULL
iMac Retina 5K, 27-inch, 2017
4.2 GHz Intel Core i7
32 GB 2400 MHz DDR4
Radeon Pro 580 8192 MB
