KorniliaP
Corners intersections
Hi everyone,
I’m running into an issue with composite wall intersections and I can’t figure out what’s causing the inconsistency.
I have two corners with what should be identical settings:
  • Same composite structure
  • Same building materials
  • Same material intersection priorities
  • Same layer order
However, when the walls intersect:
  • In left corner, the junction behaves as expected
  • In right corner, the concrete layer extends all the way to the exterior, overriding the finish layer
This happens even though both corners appear to be set up exactly the same.
Has anyone experienced something similar?
Any ideas on what I might be missing would be really helpful.
Thanks in advance!
5 Replies 5
CosminF
Do you have other elements that might intersect the corner on the right?
If you replicate the same situation elsewhere, does it show up properly?
Cosmin Furdui - architect @ Wincon
AC 27, running on Windows 11 Intel(R) Core(TM) i7-14700K CPU64, 3.40GHz, 32GB RAM, Nvidia GeForce RTX5060 32GB
runxel
Not easy to tell from the screenshot alone.
But – shot in the dark here – check if there are some elements doubled (e.g. accidentally copied in place). It will not be obvious from the plan (other than these weird connections happening).
Laurentiu
Are the small gray corners made of walls as well? having walls on walls might cause this kind of issue.
Or it could be a height difference or something to do with the reference lines of the smaller gray corner.
Laurentiu Cauni | Architect | AC 17-28 INT
Windows for AC & iOS for BIMx
Guru
Following from Cosmin, said elements need only overlap in 3D with their reference lines crossing regardless of their visibility on the current storey. If it resolves when you move the elements in question off to the side, then examine the 3D relations.
Ling.
JeffH
90% of our corner cleanup issues seem to be due to this exact issue.  That's usually the first thing to check.
AC24 / AC26 / AC27
Win10
