‎2025-01-21 12:11 PM
Hi!
I have a slab that has a surface layer has Wood. i have 2 problems with the texture orientation:
1. In plan, the texture is tilted a little bit, im guessing because i rotated my plan view and the fill is aligned orthogonally with thew original plan view? How can i align the fill with my current view? Or do i have to rotate the whole model and use 0.0º on my plan view?
2. The 3D texture orientation does not match the plan view, in fact it is rotated 90º to what I want. Shouldnt they be showing with the same orientation?
Z
Solved! Go to Solution.
‎2025-01-21 04:20 PM
No, maybe i didnt explain myself well. I want to rotate it in 2D.. i just used the 3D for explanation.
Im not getting the possibility to use "Custom Orientation" here.
Chers,
Z
‎2025-01-23 10:49 AM
Select " Link to fill Origin" you'll be able to choose the Orientation.
