Curtain Wall Problem: Frames not visible in 3D view
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
‎2015-04-08
06:44 PM
‎2023-05-24
08:51 AM
Rubia Torres
‎2015-04-08
06:44 PM
I hope someone can help me because I'm trying to find out the solution for a long time with no results.
When I draw a curtain wall (with default settings or not) I can see its frames in plan but when I go to 3D view they are allways missing, no matter what I do.
It's very annoying
(Im using Archicad 18 on Yosemite)
Solved! Go to Solution.
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2015-04-09 05:16 PM
‎2015-04-09
05:16 PM
In the Model View Options Dialog, in the Options for Construction Elements panel, make sure that the Full radio button is selected for Curtain Wall Options.
IF that is the cause you should also check and, if needed, modify your saved Model View Option combinations because some of them might contain this setting.
4 REPLIES 4
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2015-04-08 07:11 PM
‎2015-04-08
07:11 PM
Have you tried some different settings with 'Design' -> 'Modify Curtain Wall' -> 'Edit System'?
To access it you'll have to select the curtain wall.
Architectural construction designer, draftsman, modeller
ArchiCAD 25.
ArchiCAD 25.
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2015-04-09 12:47 AM
‎2015-04-09
12:47 AM
Thanks for your answer Dontknow
I have tried but no result.
It is curious that when I select a frame its boundary box is shown
Needless to say, the frames are not in invisible mode.
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2015-04-09
05:16 PM
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2015-04-10 12:29 PM
‎2015-04-10
12:29 PM
laszlonagy wrote:Problem Solved
