‎2015-04-08
06:44 PM
- last edited on
‎2023-05-24
08:51 AM
by
Rubia Torres
Solved! Go to Solution.
‎2015-04-09 05:16 PM
‎2015-04-08 07:11 PM
‎2015-04-09 12:47 AM
‎2015-04-10 12:29 PM
laszlonagy wrote:Problem Solved
In the Model View Options Dialog, in the Options for Construction Elements panel, make sure that the Full radio button is selected for Curtain Wall Options.
IF that is the cause you should also check and, if needed, modify your saved Model View Option combinations because some of them might contain this setting.
