Been a while since I worked with this code, but basically open the custom window script (CTRL+SHIFT+O), go in to 3D script and search for the WALLHOLE statement.
You should see something like: WALLHOLE n, 1 (where n = the number of polygon nodes of your shape) followed by a whole list of coordinate statements, that will most likely all end with '15'. This 15 is of interest as it is the status code that controls that you see a surface and an edge on all sides. I think if you change these to 8, it will only show a surface and no edges, but anything from 8 - 14 can be tried.
Maybe someone who scripts objects more often can give a better answer than trial and error.
I do remember that you need allways at least 1 edge showing.
The GDL Reference Guide (available from the help menu), is generally very concise and informative for these sort of things.
www.leloup.nlArchiCAD 9-26NED FULL
Windows 10 Pro
Adobe Design Premium CS5
