2004-01-10
12:50 AM
2023-05-26
03:29 PM
Rubia Torres
2004-01-10 02:07 AM
2004-01-10 06:08 AM
wkarch wrote:In this case MOD might be the best way. The standard details thaty you already have in DWG or whatever should be kept in one place and used as needed as Xrefs or just placed in the Detail window as DWGs.
Also, when I create a detail in Archicad, what is the best way to manage them to put in a library for future use. Should I save them out from the floor plan window as a .pln, .dwg or from detail window as a .mod or what. What is the best way to bring them back into the drawing. Most likely I'll want to change something on the drawing, so I don't want to Xref.
wkarch wrote:No need for this. In your Navigator, set up the Detail views and bring them into PlotMaker as any other view. Each detail window can have its own scale. If you are importing DWGs/Xreffing, the usual scale constraints apply - e.g. the DWG has to be made for the scale that the detail should be in. Don't forget that in DWG the text size is relative to the drawing, while in ArchiCAD it is goverened by the scale and defined as a printing height, that changes realtive to the drawing.
Should I put all details on a "detail story" that is set up at minus 10 feet, for example; then bring them into plotmaker? Again, I get messed up with text size unless I have a different scale detail story for each scale of detail?
2004-01-10 07:15 AM
2004-01-10 04:07 PM
2004-01-10 05:42 PM
wkarch wrote:It always stays the same PRINTED size (please don't ask me to suppy you with an Imperial example!
Djordje: Text size question. If I set a text size of say, 7 points and draw a detail on a view that has a scale set of 3/4" to a foot, will the text point size stay the same if I change the scale in the view or in the plotmaker.
2004-01-10 08:56 PM
2004-01-10 09:50 PM
2004-01-10 10:47 PM
2004-01-11 06:41 PM
wkarch wrote:Right.
Does that mean you can link multiple .pln drawings to the same plotmaker .lbk?
wkarch wrote:If you save the LBK with the drawings included, it will be. If the project is archived, then it probably is not in the same place any more - the relative paths are preserved, but the absolute is looked for and of course it is not found. You can relink. However, it is best to archive the LBK with the drawings included AND keep a PDF of the latest submitted or valid version - in that case, anybody can print it properly anywhere.
If however, you plot that .lbk at some future time, does that link have to exist in the same path, or is the detail self contained in the .lbk?
