2006-06-06
04:23 PM
2023-05-25
04:36 PM
Rubia Torres
2006-06-06 05:04 PM
2006-06-06 06:15 PM
2006-06-06 06:45 PM
2006-06-06 10:47 PM
2006-06-06 11:19 PM
2006-06-07 01:08 AM
2006-06-07 05:45 PM
2006-06-07 05:51 PM
2006-06-07 07:24 PM
Jere wrote:Do you mean that they show through in plan? If so, turn on the cover fill of your sill and make sure the backgrounds are set to a solid color (usually 91)
thanks everyone. I looked at revealMaker. For $100US i think i'll pass.
Tom, i've been trying your method, with a full height stucco wall, mesh for sill with downward subtraction, and separate wall for brick/block veneer. Everything works well, except for some reason the block veneer wall shows up through the sill mesh. I can not figure out how to get it to not show. I've played with the Display Order and that hasn't really worked. Am I doing something wrong?
edit: further, my floor slab also shows through the sills.
