We value your input!
Door Floor Plan Display
I can't seem to figure out how to get rid of the gray shaded area after I place a door. See attached image. I've played around with the floor plan door settings, but I can't seem to find the right setting to turn this off. Also what is the purpose of this shaded area?
insideru
Make sure the selected item is set to Transparent or whatever color you desire.
ARCHICAD 27 INT
macOS Sonoma
Eduardo Rolon
Also that gray area might not print since AC has a setting which changes the display of items that match the background so that you can find them.
Eduardo Rolón AIA NCARB
AC27 US/INT -> AC08
another Moderator
David Maudlin
Or uncheck the "Use Fills" check box.
David Maudlin / Architect
www.davidmaudlin.com
Digital Architecture
