2007-08-01
02:22 AM
- last edited on
2025-01-31
02:44 PM
by
Aruzhan Ilaikova
2007-08-02 07:34 AM
Ignacio wrote:The mesh seemed to me like the best way to get at this, but I can see how nasty it would be to work out all the various contours elevations.
I need to model these funky precast panels
2007-08-02 08:34 PM
2007-08-02 08:37 PM
2007-08-02 08:39 PM
2007-08-02 08:47 PM
2007-08-02 08:49 PM
2007-08-02 09:00 PM
2007-08-02 09:11 PM
Bricklyne wrote:You're a Justin Timberlake fan, huh? (You can see it on the screen capture)
........final compilation of created windows in wall shown in the 3D perspective window. As I mentioned earlier, I did it hurriedly and with few contour curves hence the low resolution mesh
( which I know I can probably change in the GDL 3D script definition, but didn't want to because it was already dragging and slow as it was in the 3D window; Note to Graphisoft - ArchiCAD NEEDs some form of geometry instancing or referencing for heavy-poly objects, and especially library objects, to allow for more complex modelling in future versions. ASAP. like yesterday; no seriously, this is a feature that is like 2-3 versions long way way overdue).
also, I noticed that when one creates an object using the mesh tool and then saves it as a library part or object, it looses it's Automatic smoothing of ridges in the 3D window as in the native mesh tool/objects. Why is this? It's not too much of a biggie except when you have to export that model or render it using a 3rd patry plugin like the Maxwell plugin where the smoothing is completely lost.....
2007-08-02 09:15 PM
TomWaltz wrote:.......not particularly. I guess it just happened to be the song playing on the internet radio station (something from Shoutcast.com - I forget which station exactly) at the time I was doing the screen capture. (Actually I wasn't even listening at the time as I had it turned down - but it's good to know)Bricklyne wrote:You're a Justin Timberlake fan, huh? (You can see it on the screen capture)
also, I noticed that when one creates an object using the mesh tool and then saves it as a library part or object, it looses it's Automatic smoothing of ridges in the 3D window as in the native mesh tool/objects. Why is this? It's not too much of a biggie except when you have to export that model or render it using a 3rd patry plugin like the Maxwell plugin where the smoothing is completely lost.....😉
2007-08-02 09:44 PM
Bricklyne wrote:It was *1.5* hours for some of the basic geometry, and realising that there was no way I was going to want to figure out and ArchiCAD-draft the projections of the paraboloids and tori and whatever in order to produce true contour lines.
\And the second thing is; 15 hours?????
