Editing wall
New to v16 and wondering why I can't just select and stretch a wall, the way I used to? My walls seem impervious to the stretch command. It's the only tool that won't come up in the floating toolbar and when I try to do it manually from the dropdown menu, that doesn't work either. What setting do I need to adjust? Thanks.
6 REPLIES 6
Are you stretching in plan or 3D?
Plan. Which brings up another question of settings. I can't seem to do any editing in 3-D at the moment. Assume it's a totally basic thing I need to adjust.
Can you post a signature with your OS, computer specs, etc. That will help in diagnosing potential problems.
No idea why you can't stretch a wall. Or 3D editing?
Windows XP version 2002 service pack 3
Intel Core 2 CPU
E8400 @ 3.00 GHz
2.99 GHz 3.00 GB of RAM
Erwin Edel
Silly question, but are groups suspended when you try to edit?
www.leloup.nl
ArchiCAD 9-29NED FULL
Adobe Design Premium CS5
Another silly question - is the wall layer locked?
Also, the wall components themselves can be locked - select the walls in question, go to Edit>Locking>Unlock or try Unlock all with nothing selected.
