Monday
Fill global scale? [Why 3'-3 3/8"???]
[context: I'm in US using imperial dimensions]
Is there a global setting that establishes the base size of any given fill?
When I use the Fill tool, I find I need to constantly select the Custom Distortion option in order to scale a variety of fill patterns.
And, when I first click on the fill to start that adjustment process, the dimension of both x & y are set to 3'-3 3/8", which is an exceptionally weird number. I guess it's anchored to 1 meter, despite the US units of the template.
Can this starting scale for the fill be modified? Where do I find that setting?
[Or, are we limited to modifying Fills by their individual scales in the Fills dialog?]
Thanks!
yesterday
Under options/element attributes/fills you'll find the fill settings
You can set the starting scale = pattern unit size
You can also use a fixed or scalable fill by the setting 'scale with plan' or 'scale independent' (model size or paper size)
