Grid display off by default?
A minor issue but annoying...
I prefer working generally with the grid display off.
When creating new worksheets and details, the grid display is on by default, and I then go into menu>view>grid display (or use assigned shortcut key) to hide grid. New elevation/section windows open with display hidden by default.
Can the default display of grid be set to off and, if so, where is this set?
6 Replies 6
No, currently this is not possible to do in ARCHICAD.
Stress Co_
Scroll to Lazlo's summary HERE
Marc Corney, Architect
Red Canoe Architecture, P. A.
Eduardo Rolon
AC20 has them set to off by default.
Eduardo Rolón AIA NCARB
AC29 US/INT -> AC08
another Moderator
thanks for the link!
When creating new worksheets and details, the grid display is on by default, and I then go into menu>view>grid display (or use assigned shortcut key) to hide grid. New elevation/section windows open with display hidden by default. I tried visiting the site to find some information but I could not find a solution.
I basically have the same question, want the grid off by default. I'll be searching for answers in the meantime but has anybody got a quick answer as to how to do this? Thanks
http://archicad-talk.graphisoft.com/viewtopic.php?p=255571#255571
