Grid options in section settings. AC12
Hey in 12 they removed an option in the section settings to update the grids manually. Now when we rebuild our sections the grids go wacky and we have to fix them every time we rebuild. Is there a way around this?
17 Replies 17
Bruce wrote:
Well, you've got further than me. I can't even get the Setting Dialog working!
This is all I get - anyone else encountered this? It's the same in v11 too.
hehehehe, yes man, nothing works in ac like it supouse to work . . .
if u want to see grid tool like u want folow these steps !
go to WORK ENVIROMENTS - TOOL SETINGS DIALOG BOXES - GRID ELEMENT TOOL !!!!
SELECT WHAT U WANT TO SEE !
PIC1
PIC 2
There is a ArchiCADWiki article with further information if you need it - http://www.archicadwiki.com/TechNotes/Grid%20Tool%20Panel%20Visibility
Bruce
That's fantastic! Why didn't I think of that?
The bizarre thing is, it was working fine before Christmas, then I come back after the break (same work environment) and it had changed.
Oh well, fixed now - and another thing learnt about ArchiCAD.
Cheers
Bruce Walker
Barking Dog BIM YouTube
Mindmeister Mindmap
-- since v8.1 --
AC27 5060 INT Full | Windows 11 64 Pro | 12th Gen Intel i7-12700H 2.30 GHz | 64 Gb RAM | NVIDIA GeForce RTX 3060 32 Gb
Dave Jochum
The insufferable rogue grid lines are back wreaking havoc in sections and elevations with the auto-staggering trick. Now it's only one grid line in the file, but I can't shake it. Delete and draw a new one, copy and paste a good one, drag a copy of a good one, close the file and start over--nothing works. And instead of just a random stagger, it's a stagger AND a correct non-stagger at the same time.
Dave Jochum
J o c h u m A R C H I T E C T S http://www.jochumarchitects.com
MBP 16" (M1 Max) 64 GB•OS 15.6.1•AC 29 Silicon (latest build)
Bruce
Dave - it's not the grid settings that do this, but rather the Section settings.
Bruce Walker
Mindmeister Mindmap
-- since v8.1 --
Dave Jochum
Yes, the bug is related to the Section setting to Auto-stagger, but it is a bug. I should not be getting a two-headed grid marker, one staggered and one not, at the same time. And in the project that was the subject of the screen shot, there wasn't any conflict that required a stagger any way.
Dave Jochum
