2024-07-01
10:55 PM
2024-07-07
08:20 PM
Do we have a tool for railing that can create the US standard. I don't believe what we have will .
The tool does not seem to be able to follow the floor as required.
2024-07-02 05:56 AM - edited 2024-07-02 05:59 AM
Place two handrails and use the Full Return option for the top one? Do not believe there is any way to do the pipe fixings.
2024-07-02 02:33 PM
Will try however this should be much easier as in a standard rail already in the template (For example this is a pain, and you cannot just extend to floor. As in extend to floor from stair - you MUST go into 2d and locate the starting point. This should be better out of the box with a ramp rail (side and center rail version) a stair rail and a mid-rail Version plus the single for aisles at seating.
2024-07-04 02:01 AM
That does not meet code. I don't know why we don't have saved ones that do follow code.. very challenging to make work. The build may be cheaper than the model
