Anna architektka
Hide upper parts of a segmental column
Hi.
I would like to hide displaying of upper parts of a segmental column. But I don´t want to use the properties window, because in some floor plans I need it to be visible and in some not.
I need it to be displayed as this.
Could you please help me?
Thank you
1 Solution
Guru
If you are not using the FPCP top limit to control the display of any other elements, you could use that as it is saved per View.
Ling.
Go to post
2 Replies 2
Guru
Ling.
Anna architektka
Hi @Lingwisyer,
thankyou for your respond. I tried to modify the FPCP settings and it works. Thank you.
