‎2022-09-24 02:40 PM
1. subtract
I thought no.
2. I have to move to the same point with two slabs to be combined.
3. Is this normal?
Or am I doing something wrong?
I would like to know the exact way to combine.
What is this phenomenon?
‎2022-09-24 06:27 PM
If your slabs are the same building material then apply a Subtraction SEO and they should then merge e.g. subtract the upper slab from the lower one.
This may help... Basic Intersection Principles
‎2022-09-25 08:22 PM
I did not combine even after SEO, so I had to move to the same coordinates to be combined.
Is moving to the same coordinates a function?
my computer has inter i7-12700F, NVIDIA 3060Ti.
‎2022-09-25 11:41 PM
Not really a function but it may have forced a redraw of the elements.
‎2022-09-27 06:38 PM
Then, if I leave it alone, does it automatically connect?
Or is there a separate command?
‎2022-09-27 08:42 PM
After application of the SEO it should automatically connect.
‎2022-09-27 08:53 PM
Are you saying that even if you don't force them to move, they will be joined later?
When I get a chance, I'll save and exit and try again.
thank you
