LeeJaeYoung
How to join slabs in cross section?
1. subtract
I thought no.
2. I have to move to the same point with two slabs to be combined.
3. Is this normal?
Or am I doing something wrong?
I would like to know the exact way to combine.
What is this phenomenon?
AC27 on window 11
6 Replies 6
DGSketcher
Legend
If your slabs are the same building material then apply a Subtraction SEO and they should then merge e.g. subtract the upper slab from the lower one.
This may help...  Basic Intersection Principles
LeeJaeYoung
I did not combine even after SEO, so I had to move to the same coordinates to be combined.
Is moving to the same coordinates a function?
my computer has  inter i7-12700F, NVIDIA 3060Ti.
AC27 on window 11
DGSketcher
Legend
Not really a function but it may have forced a redraw of the elements.
LeeJaeYoung
Then, if I leave it alone, does it automatically connect?
Or is there a separate command?
AC27 on window 11
DGSketcher
Legend
After application of the SEO it should automatically connect.
LeeJaeYoung
Are you saying that even if you don't force them to move, they will be joined later?
When I get a chance, I'll save and exit and try again.
thank you
AC27 on window 11
