How to make a window in oval stretched wall
Hello there! I need some help, solving a design problem. We've made an oval walls, using profile manager and now we want to put some windows, but when I do, it doesn't see like it should. Can you give me an advice, what can I do or maybe I have to use some other method or instrument to design it propper.
The oval details
When I put some window it is shown like this
My backup plan is to do some glass wall detail and not let it cover the all the length, but in this case they will be no windows shown in the floor plan
James B
In the Profile Manager, there is a Design Layer called "Opening Reference".
Make sure this is turn on (checkbox), and there are red lines that can define where the opening reference is. You can split these lines, or draw additional lines on this layer to follow your sloping Wall profile.
https://helpcenter.graphisoft.com/guides/archicad-21/archicad-21-reference-guide/user-interface-refe...
James Badcock
Graphisoft Senior Product Manager
David Maudlin
bonevs:
In the Profile Manager, turn on the Opening Reference lines and adjust them to the correct angle. In the Window settings, choose Preview & Positioning > Opening Plane: Associated to Wall (button under preview).
David
David Maudlin / Architect
www.davidmaudlin.com
Digital Architecture
Ooo yeah...thank you very much...it worked and solved the problem
