2026-03-21 10:04 AM
Dear All,
I have a site plan drawing in AutoCAD with the point coordinates already defined. I have inserted this plan into a worksheet already. How can I align/match the coordinates of this plan correctly in Archicad?
Thank you.
2026-03-24 02:56 AM
I’m very grateful that you shared the detailed process. It would be even more wonderful if you could review the PLN file I sent and show me the specific steps for one item, Building A, which I’m currently trying out.
Thank you very much.
2026-03-24 04:19 AM
- how to hotlink and position
- how updating works
2026-03-24 06:41 AM
Thank you very much for your video. Is there a way to set up coordinates for each building so that when linking with the Hotlink module, it automatically aligns with the master plan?
Thank you!
2026-03-24 07:16 PM
You don't have to do this and it's not recommended anyway. You position it once and you just update when you modify it.
2026-03-25 02:31 AM
...So that if you later decide to move or rotate a building you just do it in the master model with all the context, rather than changing your entire building model.
It would be interesting though if you could place a Hotlink via survey point, though outside of the initial placement, it would be more troublesome.
Ling.
| Win11 | i9 10850K | 64GB | RX6600 | Win11 | 5900X | 32GB | GTX2080TI |
2026-03-25 12:27 PM - edited 2026-03-25 12:28 PM
I tried several approaches. Best way to model and document a building is with its external walls parallel to the X and Y coordinates. If the shape is non rectangular, i usually chose to align the longest wall to the X axis. And always place the long side on X axis (matching the screen and sheet formats).
Then if you want positioning, do it in another file, or if's a single building, using survey point rotation.
2026-03-25 05:52 PM
in my expereince, there are 4 options to align coordinates with external content (dwg or ifc):
open in a separate instance, and copy/paste the raw lines/fills into your file. The 0,0,0 relationship should match the original source origin/location.
place as an x-ref (this brings in a LOT of extra layers and stuff you may not want)
use the merge function... again, brings in a lot of extra stuff
if it is a 3d file, you can use a hotlink. You could also combine step 1 (open in a separate instance), save as a pln or module, and place as a hotlink. when placing the hotlink, you have options to place in original location
the only option that is difficult to match is drag/drop, since the drawing is self contained. unless the original drafter gives you a 0,0 relationship and rotation, you are kind of sunk.
