4hotshoes
How to show expansion joints in stucco wall finish?
Part of the design of the building is to show expansion joints cut into the stucco layer of a wall assembly like trim. Joints will run from window corners both vertically and horizontally to create a grid. I have an image attached saved from Sketchup.
Todd Oeftger
AC27 Mac MacBook Pro 15", 2019, 2.3 GHz i9, 32GB, Radeon Pro 560X 4GB, 500GB SSD, 32" Samsung Display (2560x1440)
7 Replies 7
Hello 4hotshoes,
I use the curtain wall tool to do this because I can change the layout if necessary.
Christophe - FRANCE
Formateur Archicad indépendant à NANTES
Archicad 15 to 29 FRA FULL
4hotshoes
How would you do this with the Curtain Wall tool? What parts would create the joints, stucco? I have a 2x6 stud wall.
Todd Oeftger
You could have a Curtain Wall with invisible frames, so the visible geometry would be just panels. When defining the panels you could specify the thickness of the panels, which would be equal to the depth of the joints, and also the gap between panels, which would be the width of the joints. Then you could just place the Curtain Wall in front of the Wall, and place it on a separate Layer so you can make it visible or hidden, as needed.
AS you may know, you can also simply place am empty Curtain Wall (no pattern), then go to an Elevation, select the Curtain Wall, go to Edit Mode and simply draw the positions of the Frames (invisible Frames, so they would actually define the joints).
jakubc7
4hotshoes the curtain wall suggestion is probably quite a good one but I know the tool may be little intimidating if you haven't used it before.
Method I tend to use is to model columns and beams where you want the score lines to be. Make sure the building material has a higher priority than the walls and place it on the hidden layer.
Columns and Beams do not need to be substituted from the walls (ie. no need to use Solid Element Operations) as they subtract automatically when hidden. I find this to work very well.
ArchiCAD 10 - 25 | Windows 10
ARCHIcreate | Perth, Western Australia
archicad solutions | content creation | training | software implementation
I agree with jakubc7. Columns and Beams are much more simpler and easy to control.
Our good friend Jared Banks from Shoegnome posted a tutorial with this technic sometime ago.
But it is still valid.
Yes, I agree, that is a pretty good solution.
I've always used the Trussmaker tool, which can be SEO'd, or just use a thin, dark gray material and leave the truss on the surface. It's hard to tell the differences in depth. Beams and columns obviously work, too.
Richard
AC26 (since AC6.0), Win10
