2010-11-07
01:30 AM
2023-05-25
05:05 PM
Rubia Torres
2010-11-07 03:10 AM
2010-11-07 12:16 PM
2010-11-07 01:55 PM
2010-11-07 02:23 PM
David wrote:Windows and doors are fine, as long as I can create roofs/mesh that are translucent or that use glass materials. Again the school doesn't 'like' us to use a standard 2MX1.8M high door, or even a square door... The image I posted: the front part i.e closest to the camera is part of the 'front entrance'...
NStocks:
1. Using Mesh: you can save ArchiCAD elements as library parts, when saving them you choose which side is up so you can rotate the Mesh. For more information with images, go to Help > ArchiCAD Help, when your browser opens click on the "Search" tab, and input "Saving 3D Models as Objects" in the search box, in the results list "Saving 3D Models as Objects" will lead to detailed information.
2. Using Roofs: Each plane would be one roof, so you would need as many roofs as there are planes. You can select and stretch roof nodes in the 3D Window so they meet other to create your design.
Neither of these solutions will accept windows and doors, so creating openings will be another issue.
2010-11-07 03:04 PM
2010-11-07 04:44 PM
2010-11-07 05:03 PM
2010-11-07 05:07 PM
2010-11-07 10:51 PM
