I am trying to manually change the height of a wall
4hotshoes
When I select the wall to drag the top of the wall up, I am not getting the option to do this in the pet pallet. What am I doing wrong? I want to stretch the wall up to the peak of the roof and then trim it to the roof.
Todd Oeftger
AC27 Mac MacBook Pro 15", 2019, 2.3 GHz i9, 32GB, Radeon Pro 560X 4GB, 500GB SSD, 32" Samsung Display (2560x1440)
4 REPLIES 4
DGSketcher
Legend
See if this helps...
https://helpcenter.graphisoft.com/guides/archicad-22/archicad-22-reference-guide/interaction/editing...
Eduardo Rolon
Click on the second icon on the top row, that is the one for the vertical stretch.
Eduardo Rolón AIA NCARB
AC27 US/INT -> AC08
another Moderator
4hotshoes
Thanks for that. I was looking for a different graphic symbol and did not know what that was for.
Todd Oeftger
Stress Co_
If you have "Help Tags" turned on
(on a Mac, click the "Help" pull down menu,
it may be the second item in list), when you have
the pet palette open. Hover over any of the icons
and the tag will appear with the command's function.
Marc Corney, Architect
Red Canoe Architecture, P. A.
