2023-07-26 11:19 PM
I want to show that the insulation should be also fixed to the walls. I created a wall and used the same building material. The hatch was horizontal so I had to copy the building material and hatch (90 degree turned).
But the hatch is not within the wall lines.
Any idea?
I talked to the helpline but they couldn't figure it out either
2023-07-27 03:18 AM
You should not need to duplicate and rotate the fill. Check your Building Material settings.
Ling.
Win11 | i9 10850K | 64GB | RX6600 | Win10 | R5 2600 | 16GB | GTX1660 |
2023-07-28 09:11 PM - edited 2023-07-28 09:11 PM
FYI: The "Fit to Skin" option of the "Fill Orientation" field being the relevant setting here.
