Insulation wall hatch not aligned
Sandramuller
I want to show that the insulation  should be also fixed to the walls. I created a wall and used the same building material. The hatch was horizontal  so I had to copy the building material and hatch (90 degree turned).
But the hatch is not within the wall lines.
Any idea?
I talked to the helpline but they couldn't figure it out either
Guru
You should not need to duplicate and rotate the fill. Check your Building Material settings.
Ling.
FYI: The "Fit to Skin" option of the "Fill Orientation" field being the relevant setting here.
