Intersection between concreate wall and brick wall in plan
HJ1
HI,
I have been working on a plan in which i have made a brick wall and concreate wall intersection.
now i want to have a clear intersection between these two walls.How can i do that ??
thank you
7 REPLIES 7
The join (or mitre) should be automatic.
Are the walls in the same layer?
Can you select the wall and show that so we can see the reference lines/
Guru
Make sure you do not have any other walls whose reference line intersects with the junction, even at different elevations.
I have tried to intersect both of the walls... Both walls are in the same layer. But their materiality is different.
How did you make that junction of two walls?... I tried to do so... But it is still making such junctions only.
No, there are not any other walls intersecting at that point rather than these 2 walls.
It seems the angle of the connection has an effect.
Guru
You can faux the connection with a really thin wall of the stronger Building Material on the bisector with the Reference Line on the inside. I made it 0.001 in the example below.
Ling.
It is also possible to use Polygonal Walls for this connection, which lets you model the exact shape for both.
Setup info provided by author
