HJ1
Intersection between concreate wall and brick wall in plan
HI,
I have been working on a plan in which i have made a brick wall and concreate wall intersection.
now i want to have a clear intersection between these two walls.How can i do that ??
thank you
7 Replies 7
The join (or mitre) should be automatic.
Are the walls in the same layer?
Can you select the wall and show that so we can see the reference lines/
Guru
Make sure you do not have any other walls whose reference line intersects with the junction, even at different elevations.
HJ1
I have tried to intersect both of the walls... Both walls are in the same layer. But their materiality is different.
How did you make that junction of two walls?... I tried to do so... But it is still making such junctions only.
HJ1
No, there are not any other walls intersecting at that point rather than these 2 walls.
It seems the angle of the connection has an effect.
Guru
You can faux the connection with a really thin wall of the stronger Building Material on the bisector with the Reference Line on the inside. I made it 0.001 in the example below.
Ling.
It is also possible to use Polygonal Walls for this connection, which lets you model the exact shape for both.
