Intersection fails
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
‎2015-05-19
03:41 PM
‎2023-05-24
08:50 AM
Rubia Torres
‎2015-05-19
03:41 PM
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2015-05-19 06:12 PM
‎2015-05-19
06:12 PM
Most of the time this happens because there is a Wall on a hidden Layer and your visible Walls intersect with that Wall. You can find this out by making all your Layers visible.
This article can help you in handling such situations. Layers have an Intersection Number and the rule is that Walls and Beam will intersect with Walls or Beam that are located on a Layer with the same Layer Intersection Number. (Please note that you can save Layer Combinations and the Layer Intersection Number of a given Layer can be different in different Layer Combinations):
http://helpcenter.graphisoft.com/guides/archicad-18-int-reference-guide/configuration/attributes/lay...
Options
- Mark as New
- Bookmark
- Subscribe
- Mute
- Permalink
‎2015-05-20 11:40 AM
‎2015-05-20
11:40 AM
Oh thanks! Good to know for the future, this time though I found that I had forgotten that I had changed the heights on some of the walls but not on the other ones, when I had changed so that they all were the same, it intersected properly... So obviously you can't have different heights of the walls on the ground floor without it being marked, which actually is a pretty good function to make you notice ^^ Now I know that...
