2014-02-28 12:19 AM
2014-02-28 02:36 AM
2014-02-28 08:04 PM
2014-03-01 09:47 AM
2015-09-03 03:13 PM
2015-09-03 08:02 PM
2015-09-04 03:54 AM
Thomas wrote:This only works for section views if each view is for a separate section viewpoint (I think I got the terminology right this time).
This works fine for section views, the reference remembers its different positions fine for each view.
What am I doing wrong?
Why doesn't saved views work the same in floor plan vs. section views?
2015-09-04 06:49 AM
2015-09-04 04:00 PM
Thomas wrote:Barry is right. The Floor Plan Viewpoint and the 3D Viewpoint are special in this regard because there is a single Viewpoint for all Stories, and a single Viewpoint for 3D perspective/parallel projections.
Clear as mud. Each storey displays as a different viewpoint in the Project map just like the views do in the view map.
The trace/reference chosen is a view aspect. We should be able to store various references with views. Having to attach the same ref several times and use tricks to hide them is ridiculous.You should make this into a wish, see how much support it gets.
This needs to be cleared up!
2015-09-05 12:52 PM
laszlonagy wrote:Look, Lazlo, I know he's right. And you're right that it's a legacy thing. I've been with this crowd long enough to see that.
Barry is right.
