2015-12-30 07:02 PM - last edited on 2023-05-26 02:09 PM by Rubia Torres
2015-12-30 09:48 PM
another Moderator
2015-12-30 10:55 PM
ejrolon wrote:Sorry, I'm new to ArchiCAD. Where can I find the floor plan display settings? The problem is, that AC19 do not apply my modifications if you mean the "Floor Plan" Button in the Info-Window?
Working here. Check the Floor Plan Display settings.
2015-12-30 11:00 PM
another Moderator
2015-12-30 11:27 PM
ejrolon wrote:that's unfortunately the problem. My ArchiCAD does not apply those settings… I reinstalled etc. but that does not work for me… 😕
Try this:
• Select the Column
• Right Click and select "Column Settings"
• Look for "Show on Stories" and select "All Relevant Stories"
• Then change "Floor Plan Display" which is the next one to "Projected" or "Projected with Overhead"
Just to be sure that you are editing the one you already placed and not the next one.
Also check that the height of the column.
2015-12-31 04:50 AM
another Moderator
2015-12-31 04:32 PM
2016-01-01 07:35 AM
ejrolon wrote:Just to be absolutely certain: You DO use the coloumn fro the toolbox-menu, and not a coloumn-object? Because, if my mind doesn't play me any tricks, objects are not visible from other stories than its home story. Just checking
Does not make sense.
Please verify that you have the latest update and if that does not help then you will need to get in touch with your reseller.
2016-01-01 04:27 PM
Kamelite wrote:Look at Object Settings > Floor Plan and Section > Floor Plan Display > Show on Stories: there are a number of options for showing Objects on more than their home story.
Because, if my mind doesn't play me any tricks, objects are not visible from other stories than its home story. Just checking🙂
2016-01-01 04:58 PM
David wrote:That's interesting, gotta check that out. Because I've had trouble using the chimney object, for instance. It wasn't visible on other stories than its home story. Which can be a little troublesome in a multi-story house. I switched to using a square coloumn with the same dimensions instead... I might have to revue that nowKamelite wrote:Look at Object Settings > Floor Plan and Section > Floor Plan Display > Show on Stories: there are a number of options for showing Objects on more than their home story.
