Issue with displaying on all relevant stories
Hello community,
I'm currently using AC19 on my Mac OS X (10.11.2). I cannot display columns on all relevant stories. While clicking on the "show on all relevant stories" element in the "Floor Plan and Section" menu, ArchiCAD do not apply those settings. Anyone facing the same problem?
Thanks and best regards
Mladen
9 REPLIES 9
Eduardo Rolon
Working here. Check the Floor Plan Display settings.
Eduardo Rolón AIA NCARB
AC29 US/INT -> AC08
another Moderator
Sorry, I'm new to ArchiCAD. Where can I find the floor plan display settings? The problem is, that AC19 do not apply my modifications if you mean the "Floor Plan" Button in the Info-Window?
Eduardo Rolon
Try this:
• Select the Column
• Right Click and select "Column Settings"
• Look for "Show on Stories" and select "All Relevant Stories"
• Then change "Floor Plan Display" which is the next one to "Projected" or "Projected with Overhead"
Just to be sure that you are editing the one you already placed and not the next one.
Also check that the height of the column.
AC29 US/INT -> AC08
another Moderator
ejrolon wrote:
Try this:
• Select the Column
that's unfortunately the problem. My ArchiCAD does not apply those settings… I reinstalled etc. but that does not work for me… 😕
Eduardo Rolon
Does not make sense.
Please verify that you have the latest update and if that does not help then you will need to get in touch with your reseller.
AC29 US/INT -> AC08
another Moderator
Check and make sure your columns are actually crossing the story you want it to display in and they are being cut by the current floor plan cut plane.
Kamelite
Just to be absolutely certain: You DO use the coloumn fro the toolbox-menu, and not a coloumn-object? Because, if my mind doesn't play me any tricks, objects are not visible from other stories than its home story. Just checking 🙂
Happy new year!
.Kamelite
Windows 10, Archicad 28
David Maudlin
Look at Object Settings > Floor Plan and Section > Floor Plan Display > Show on Stories: there are a number of options for showing Objects on more than their home story.
David Maudlin / Architect
www.davidmaudlin.com
Digital Architecture
AC29 USA Perpetual • Mac mini M4 Pro OSX15 | 64 gb ram • MacBook Pro M3 Pro | 36 gb ram OSX14
Kamelite
That's interesting, gotta check that out. Because I've had trouble using the chimney object, for instance. It wasn't visible on other stories than its home story. Which can be a little troublesome in a multi-story house. I switched to using a square coloumn with the same dimensions instead... I might have to revue that now 🙂
I guess its never to late to learn something new!
Thanx for enlighting me
.kamelite
