yesterday - last edited yesterday by Barry Kelly
Is there any possible way to split or divide the mesh (terrain) in two parts, one inside the sheet-pile wall and the other outside the wall?
Best regards
Jesper
Solved! Go to Solution.
yesterday
If the sheet-piles are columns or objects, then unfortunately you can not magic wand to them.
However, convert them to morphs and you can magic wand up to them.
Work on a copy that you can convert to morphs, so you can keep the original columns or objects as they are.
yesterday
Your mesh looks quite flat, so I was going to say simply cut a hole and then fill with a new mesh.
But if it is not level then duplicate it.
Cut a hole in one and then subtract the outer area from the copy, and then move it back into the correct place.
yesterday
Thank Barry,
This will probably work, but is there a way to make the cut-out follow the contour of the sheet-piles with SEO or a other method?
Best regards
Jesper
yesterday
yesterday
Thank's a bunch Barry 👍
