Louvered Hollow Doors
krab-El
Hello, How to create a louvered Hollow Door?
But we can already do that with the D1 Door included in the Library.   You will need to make a Custom Handle for the door - but this is the door you can use to get what you are asking for.  It's not the usual way to size a door.  Typically the door is sized per the door panel size - not the outside of the frame size.  Also, the size of the louvers may differ from one manufacturer to another.
You can add what ever Annotation you want to a Door Legend.
5 REPLIES 5
David Maudlin
krab-El:
In the US library, this door has these options. Check your local library.
David Maudlin / Architect
www.davidmaudlin.com
Digital Architecture
Steve Jepson
Provide the manufacture/model and I can make one for you exactly like it.   There are of course several ways to make a door like that - depending (as always) on what you need to do with it.
What do you need to display in Interactive Schedules?
Do you need a Door Library Part that has a vent that you can change to whatever size you want? Or is it a door that would always have a vent the same size in it ?
Hello, thank you very much for being willing to help. Here is the model of the door I need. I want to be able to modify the size of the vent and display all the dimensions in the schedule.
Okay, thanks for your contribution.
