Missing Surface List in Info Box and Tool Box
Sefa Yakut
After clicking on any tool in Archicad, when I click on the surface list in the info box, the list does not appear. Also when I try the same in Tool Box, there is no surface list, I only see it as a line.
7 REPLIES 7
Ricardo Lopez
Hi @Sefa Yakut
Try to restore the defaut work environment profile of your choice by clicking on Options > Work Environment > Apply Profile
Best regards.
M. Arch. Ricardo López
I tried this but nothing changed. I also tried importing the work environment from a non-issue file but again it did not solve the problem.
Br,
Do surfaces work for other tools?
No, surfaces don't work for other tools either.
Br,
Hi @Sefa Yakut
I know it may seem a bit drastic, but perhaps an alternative might be to reinstall the program. šŸ˜
Ricardo.
Just out of interest, what is your screen resolution and have you scaled the screen size in the Windows Display setting (100% is recommended).
Also, since it seems to be a display issue, it is always a good idea to make sure that you have the latest graphics card drivers installed on your system.
Setup info provided by author
