Move one segment of wall
Arctushar
Hi
I have drawn a wall with multiple segments.  I mean a wall like polygon. Now I want to move only one segment like stretch. I cant select only one segment, it is selecting all segment. Also want to know how to move or stretch one point. For example I have a L shape wall. Now want to edit the corner point 300 mm at x direction.
1 REPLY 1
Single elements drawn with the continuous method will 'autogroup' if you have that option turned on (it is by default).
You need to 'suspend' the groups to be able to select individual elements.
