New Archicad 19 Dock feature
AHRRR! I'm trying to get use to this dock in 19, but it's driving me crazy (short putt actually) I can't open a window over the new dock 'feature'.
It's nice that I can cleanly arrange my pallets but Jeeze! It's way too hard/counter intuitive to do that and if i want to open the archicad forum from the help menu or switch over to 'finder', my Archicad continues to float over top of it. I have to minimize Archicad to get to other windows! Worse and most convenient of all, the search and select pallet keeps disappearing behind the window also!
..Pain, ...Pain, ...Pain!
Archicad version 19 on Mac OS X Yosemite 10.10.3
my best wishes and condolences to you all,
Frustrated Frank
15 REPLIES 15
rjwilden
While not using 19, the way I setup my computer should work for any system.
I set up 3 desktops, one for Archicad, another for browser and email another for finder. I have a Logitech MX master mouse with additional buttons and a side wheel. I set the side wheel funtion to "navigate between apps"
When I scroll, all the apps I have open flash up on the screen, I select the one I want and it takes me to the desktop it is on. No opening apps or moving stuff around. Big time saver.
Richard Wilden Design. Ltd
Dunedin, New Zealand.
Imac 27" i9 3.6GHz; 32GB Ram Mac OS 11.3
Archicad V23:V24
JaredBanks
Mentor
Not 100% sure what you mean, but right click on the tab and select undock. Then you can have a floating window. You can also turn off the whole docking/tab function if you don't like it.
Jared Banks, AIA
Shoegnome Architects
JaredBanks
Mentor
If you are talking about ARCHICAD not playing nice with windows from other applications, I'm not sure what's going on. I'm not seeing that behavior with the same set up (19 and OSX 10.10.3).
Jared Banks, AIA
David Maudlin
Frustrated Frank:
In the Work Environment > User Preference Schemes > Dialog Boxes and Palettes: uncheck Keep ArchiCAD Palettes visible even when another application is in front.
David Maudlin / Architect
www.davidmaudlin.com
Digital Architecture
Stress Co_
I'm trying to replicate my AC18 work environment and cannot get
my "toolbox tools" palette to sit to the right of the "Navigator" palette.
It just won't attach into that position
Marc Corney, Architect
Red Canoe Architecture, P. A.
Erich
Not my normal arrangement, but it worked for me. Try dragging your navigator over rather than the tool box inward.
Erich
AC 19 6006 & AC 20
Mac OS 10.11.5
15" Retina MacBook Pro 2.6
27" iMac Retina 5K
James B
There are technical and functional differences between Palettes and Toolbars. Like on Windows, Toolbars can only be placed around the extremity of the work environment - Toolbars also don't stretch/expand like Palettes.
This is the difference you are seeing above. The main Toolbox is a Palette, but there is also a Toolbar Toolbox set as well (with smaller icons).
James Badcock
Graphisoft Senior Product Manager
Stress Co_
Yep... I was using the "Toolbar" toolbox
(Trying to save every pixel of screen real estate).
It works when I switch to the "Palette" Toolbox.
Thanks
aahatimo
I did have that problem when setting up my new WE. I switched to legacy view mode and all was well, then switched back to my WE and all worked fine. Thanks for reminding me where the checkbox was David! But box was unchecked. No sure what was up, but its working now. Maybe not the most logical place for the option, plus not only the palletes were covering other applications, the entire AC 19 screen was.
David wrote:
Frustrated Frank:
tim hanagan
aaha! design studio durango, co
27" retina 5k iMac 4ghz i7 os 10.13.6 m395x 4 mb, 32gb ram, 512 gb ssd ac 22 current
15" retina mbp 2.6ghz 1mb 16gb ac 22 current[/size]
