‎2004-06-15
04:57 PM
‎2023-05-26
12:43 PM
Rubia Torres
‎2004-09-13 08:36 PM
MarinRacic wrote:Hmmmm ... have to meet you at last ... inshallah ...
I know, but tracing sometimes isn't so simple and if I magic-wand it I get the whole slab. Once I did a Disney store which didn't have a single straight shelf, all were radial + they were different at every level (3 levels)... Tracing was, let's say, a bit of a pain in the b...
‎2004-09-13 08:41 PM
Donald wrote:Not if you keep the cursor on the reference point/edge.
Matthew Lohden wrote:
Is there a reason that Drag > press option/alt to copy > type "r" > enter distance doesn't work for you?
this is inaccurate as the distance becomes whatever you dragged plus "r" distance input.
‎2004-09-13 08:50 PM
‎2004-11-11 12:46 AM
‎2004-11-12 10:56 AM
‎2005-01-26 06:14 PM
‎2005-01-26 08:05 PM
‎2005-01-28 07:55 AM
TomWaltz wrote:Agreed.
Keith has a point.
There is a fundamentl difference between AutoCAD and Archicad Offset commands.
Autocad offset offsets a single object. Archicad's offset is a drawing method when you are already in a command. It almost seems semantic, but it is a key difference.
‎2005-01-28 10:54 AM
‎2005-01-28 12:50 PM
