Friday
Hi!
I just bought a 16 inch MBP with M1 Pro. After downloading Archicad I noticed that when I want to create or edit a wall (could be any. other object) the black lines that would show you where that wall will be created or how they would be edited, I can't see them. If I click, sure thing the wall creates to te point clicked.
I noticed that the only way I can see the path is to hover over the pop-up menu (Image 2) and then I can see. In case there is a need for more info I can provide.
I would be grateful if anyone could help me.
Operating system used: Mac Apple Silicon 15 Sequoia
Solved! Go to Solution.
Friday - last edited yesterday by Laszlo Nagy
What version of Archicad?
Is it the latest build?
There was another post I remember that was similar for Archicad 26.
But installing the latest update fixed that.
3 hours ago
Hello!
Thanks for your response, the Build is 3001 INT. Thanks for the link, seems we have the same problem. I will try to update Archicad.
Thank you again!
