Learn more
Karol Lozinski
Problem with intersecting materials
There's a problem with intersecting 3 walls. I'd like to know how to get rid of insulation fill I marked blue and why walls' cores won't merge (marked red). I did some changes in intersection priority (very low value for insulation and very high for wall) but it doesn't seem to work
AC 28 Win 11
2 Replies 2
Karol Lozinski
Also, can I set somewhere priority of visibility of some things? For example I'd like to have all the new thing I draw on the very top. It's really annoying when I draw some fill and can't even TAB to it, so I have to move some things above it to change its display order
AC 28 Win 11
Steve Jepson
It is hard to tell exactly what your trying to do. Something like this?
I don't have your exact fills but if you want to use the Attributes Manager you can put them in a .zip file and add them to your post as an attachment. ?
