2024-09-03
10:26 AM
2024-09-03
10:31 AM
Noemi Balogh
I watched some videos on YouTube on how to make 3D roof tiles. But when I tried to split my roof, it suddenly disappeared.
2024-09-03 02:59 PM
What disappeared, the roof or the tiles?
Tiles done with the roof accessory add-on will disappear when you split the roof.
The roof should remain and you will have to apply the accessory again.
2024-09-03 05:36 PM
The roof sir. I am trying to apply the accessories but first I need to split the roof. But when I split it, it suddenly disappeared instead of separating the roof planes.
2024-09-04 04:01 AM
So, you have a multi-plane roof and you right click and choose 'split into single roof planes' ?
If that is the case, I have not known roofs to disappear.
Can you show a screen shot of the roof while selected before the split.
04:05 AM
2024-12-04
10:33 PM
Here it is sir Barry,
2024-09-04 04:19 AM
Very strange.
The roof appears to be in its own storey, but that should not matter.
I can't see anything else unusual.
The roof is grouped with something, but again that should not matter.
Does the same happen if you select and split the roof in plan?
2024-09-04 05:09 AM
Yes, I tried it in the plan also. It's the same thing happening.
Also, I tried doing it on a new and clear file and still the same. I wonder If I accidentally pressed some settings here. I'm kind of new to this software, so I can't proceed with my exploration.
2024-09-04 07:08 AM
I am at a loss.
You should end up with the exact same roof but in single planes.
ALT-click on the multi-plane roof so you have those settings as default, and then model a single plan instead of a multi-plane roof.
If you can see that single plane roof, then I have no idea what the problem can be.
02:15 AM
2024-12-04
10:30 PM
Hi! I'm having the same issue.
When I split the roof into planes, the roof disappears.
Any solution?
Thanks
2024-11-29 04:37 AM - edited 2024-11-29 04:38 AM
Check your Filter & Cut Elements in 3D settings (ctrl + alt + a). If your roof is on a storey that is getting filtered out, it may have been originally visible due to a Selection, but once updated it would disappear.
Ling.
AC22-28 AUS 3110 | Help Those Help You - Add a Signature |
Win11 | i9 10850K | 64GB | RX6600 | Win11 | R5 2600 | 16GB | GTX1660 |
