ā2021-04-15
05:44 PM
ā2023-05-25
04:35 PM
Rubia Torres
ā2021-04-15 08:40 PM
ā2021-04-16 01:17 AM
ā2021-04-16 02:21 AM
ā2021-04-16 03:04 AM
ā2021-04-16 04:30 AM
ā2021-04-16 07:02 AM
ā2021-04-16 08:19 AM
Jeff wrote:
The problem with that approach Barry is that as soon as you modify the bottom end using the edit tools you break the associativity of whatever node or segment you customized. This is OK only if EVERY other aspect of the handrail is correct and doesn't get modified later. Unfortunately this is almost never the case in practice.
ā2021-04-16 09:05 AM
ā2021-04-16 10:44 AM
Lingwisyer wrote:Exactly! This is the solution that should be obvious here.
It would be nice if they made only the parameter you edited non-associated whilst all of the other settings remain. Quite a few times I have just wanted a different offset for one or two segments...
