2015-10-29
02:25 AM
2023-05-23
04:20 PM
Rubia Torres
2015-11-10 01:23 AM
2015-11-10 11:17 AM
Rogerdodge wrote:I can second that. Just spend some time drafting with fills or slabs etc and giving edges offsets, it will happen at some point. I get multiple instances throughout the day, but it is tricky to reproduce right after. So it seems a bit random, perhaps related to zooming and panning before it happens or snapguides being drawn.
This issue seems to happen to me mostly when using the stretch command with polygonal fills, give that a go.
2015-11-10 11:40 AM
2015-11-10 04:48 PM
2015-11-10 04:49 PM
2015-11-10 09:51 PM
2015-11-10 11:52 PM
Eric wrote:The PDF is likely triggering the issue similar to what lasse has mentioned about have a fill in the background. The investigation is underway.
We just noticed this issue today. It seems to only happen when tracing over a PDF. Anyone else notice that?
2015-11-11 04:10 AM
2015-11-12 10:24 PM
DGSketcher wrote:Same here. I often have to zoom way in to get an accurate snap.
AC used to be really good at snapping to the obvious requirement. Since v19 I am getting frequent "errors" where the snap point is just off a corner but has snapped to an edge. The new blue line guides are clever, but they may be being too clever...
2015-11-16 02:58 PM
Erwin wrote:Often I'm also holding down Shift key for ortho and as we know in AC19 that not working normally.
I had one colleague who would hold down SHIFT to keep things 'ortho' and then at the very last moment did something by first letting go of SHIFT and nudging his mouse before typing to basically make the whole process of holding down SHIFT redundant.
